I am trying to configure hestiacp. The correspondence works, but the control panel notifications (email account creation, user account creation) are not sent by the system. What else and where do I need to set it up for it to work? I opened these ports: 8083, 80, 443, 143, 993, 110, 995, 25, 465, 587
Ohhh… I didn’t know that…
It is strange, because I also enabled the ports required for sending mail in the Oracle control panel, and by typing the netstat -plntu command, it can be seen on the console that it is listening on that port.
OK, I moved from Oracle cloud to Linode.
Installed, but SPF and DKIM records missing from control panel hostname, wich is a subdomain (hcp.mydomain.xy)
exim4 mainlog
2023-08-11 10:40:41 1qUPZR-0006KJ-UC <= [email protected] U=admin P=local S=1337 id=t7IjIq4ocoRvnta0xGdEeFj4adKOfsYjAG1lQazk@localhost.localdomain
2023-08-11 10:40:42 1qUPZR-0006KJ-UC H=gmail-smtp-in.l.google.com [142.250.27.27] TLS error on connection (recv): The TLS connection was non-properly terminated.
2023-08-11 10:40:42 1qUPZR-0006KJ-UC H=gmail-smtp-in.l.google.com [142.250.27.27] TLS error on connection (recv): The specified session has been invalidated for some reason.
2023-08-11 10:40:42 1qUPZR-0006KJ-UC ** [email protected] R=dnslookup T=remote_smtp H=gmail-smtp-in.l.google.com [142.250.27.27] X=TLS1.3:ECDHE_X25519__ECDSA_SECP256R1_SHA256__AES_256_GCM:256 CV=yes: SMTP error from remote mail server after pipelined end of data: 550-5.7.26 This mail is unauthenticated, which poses a security risk to the\n550-5.7.26 sender and Gmail users, and has been blocked. The sender must\n550-5.7.26 authenticate with at least one of SPF or DKIM. For this message,\n550-5.7.26 DKIM checks did not pass and SPF check for [hcp.mydomain.xy] did not\n550-5.7.26 pass with ip: [170.187.190.142]. The sender should visit\n550-5.7.26 https://support.google.com/mail/answer/81126#authentication for\n550 5.7.26 instructions on setting up authentication. i13-20020aa7dd0d000000b0052334349854si3206915edv.44 - gsmtp
2023-08-11 10:40:42 1qUPZS-0006LE-C5 <= <> R=1qUPZR-0006KJ-UC U=Debian-exim P=local S=3951
2023-08-11 10:40:42 1qUPZR-0006KJ-UC Completed
2023-08-11 10:40:42 1qUPZS-0006LE-C5 remote host address is the local host: hcp.mydomain.xy
2023-08-11 10:40:42 1qUPZS-0006LE-C5 == [email protected] R=dnslookup defer (-1): remote host address is the local host
2023-08-11 10:40:42 1qUPZS-0006LE-C5 Frozen
2023-08-11 10:43:28 no host name found for IP address 45.91.171.169
2023-08-11 10:43:28 SMTP call from [45.91.171.169] dropped: too many syntax or protocol errors (last command was "?\b?\006?\027?\030?\031?\v?\002\001??\r?", NULL)
Where can I see the spf and DKIM settings for the domain of the control panel on the control panel?
Control panel: hcp.mydomain.xy
