Testing Hestia Control Panel v1.9.0 Beta Released 1
first test
Debian 12
Testing install of
Hestia Control Panel v1.9.0~beta1
wget https://beta-apt.hestiacp.com/hst-install-debian.sh
bash hst-install-debian.sh
Installation itself no errors.
simple test of “file manager” is working.
change Language to dutch and back to english. Language change is Working no problems.
Plugin Change “File System Disk Quota” to yes get error :
“Error code: 127”
Plugin change “Web Terminal” to yes
set user “SSH Access” to bash
set user “Jail User Shell” no
click on “Web Terminal” on the top and get the Web Terminal with a error.
“Connection error.”
server settings => web-terminal = off (start not working)
second test
Debian 12
Testing install of
bash hst-install-debian.sh --apache no --phpfpm yes --multiphp no --vsftpd yes --proftpd no --named yes --mysql yes --port ‘8083’ --hostname ‘[domainname]’ --webterminal yes --username [name] --resourcelimit yes --email ‘[emailaddress]’ --password ‘[password]’ --exim yes --dovecot yes --sieve yes --clamav yes --spamassassin yes --iptables yes --fail2ban yes --quota yes --api yes --interactive yes --mysql-classic no --postgresql no --with-debs no --lang ‘nl’
one little error about the quota.
(but this is normal because I already had my quota installed.)
Plugin Change “File System Disk Quota” to no and then to yes get error :
“/dev/sda3 [/]: group quotas turned on
/dev/sda3 [/]: user quotas turned on”
server settings “Web Terminal” is on try to restart “Web Terminal” get error “Error: ERROR: Restart of web-terminal failed.”
server settings “Web Terminal” edit and stop not working.
Plugin Change “Limit System Resources” to no get error :
“Error code: 1”
“Error code: 127”
Just updated my test system from v1.9.0~alpha to v1.9.0~beta1. It was a standard installation, nothing special selected. I’m running a wordpress site, DNS and email. No problems found so far.
did you found any fix for this ? im still getting Plugin Change “File System Disk Quota” to yes : Error code: 127. even with fresh install of v1.9.3
Please attach the error log! Easy to track and find problems!
i did check the /var/log/hestia nothing related to Disk Quota do you know where is the logs for this issue ?
