Any ETA on when will the new packge be release that’s fully support 20.04?
Cheers
No, not yet… We are currently testing all the features and improvements
So it was installed without problems. Everything that I tried on the test server (Ryzen 3950x 128G) so far works without errors (web, DB, DNS, Mail). Perhaps a release soon? ![]()
Maybe, this bug was already fixed…
Is there any known bugs left for 20.20?
For 20.04, there is currently no known bug left (that wouldnt be in our github issue list).
Did a upgrade last night from 18.04 to 20.04 but I had some issues
root@cp:/sbin# ln -s /usr/sbin/iptables /sbin/iptables
root@cp:/sbin# ln -s /usr/sbin/iptables-save /sbin/iptables-save
root@cp:/sbin# ln -s /usr/sbin/iptables-restore /sbin/iptables-restore
Solved my errors please check which -a iptables-save
It will create a symbolic link from /sbin/ to /usr/sbin for iptables, save and restore
Yes, made links and now IPtables is not greyed out.
I can stop and start it, but restart fails with error message
““Restart” “” failed”
Run via command
Try to run the command from command line
v-restart-service iptables
To check the output
I have currently no issues with it
Blockquote
/usr/local/hestia/bin/v-stop-firewall: line 73: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 74: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 75: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 76: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 77: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 78: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-stop-firewall: line 79: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
chmod: cannot access ‘/usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks’: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 180: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 181: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 182: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 183: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 184: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 185: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 186: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 187: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
/usr/local/hestia/bin/v-update-firewall: line 188: /usr/lib/networkd-dispatcher/routable.d/50-ifup-hooks: No such file or directory
Error: ERROR: Restart of iptables failed.
Blockquote
Please check if /usr/lib/networkd-dispatcher/routable.d/ exists
Checked it does not exist.
test -d “/usr/lib/networkd-dispatcher/routable.d/” && echo “exist” || echo “Nope”
Nope
Create that folder as root It should work…
Yes, now it works - no errors!
Any plans or timeline to update the main script?
https://raw.githubusercontent.com/hestiacp/hestiacp/release/install/hst-install.sh
is not supportiong Ubuntu 20.04
https://raw.githubusercontent.com/hestiacp/hestiacp/master/install/hst-install-ubuntu.sh
seems borked now as well (that worked a few weeks ago,.
Installation Aborted
Install script does not match Hestia release version
Please use the installer from the release branch
To test the beta version you need to build the hestia deb packages and re-run the installer
./hst_autocompile.sh --hestia no
./hst-install.sh … --with-debs /tmp/hestiacp-src/debs
Hmm, does not look broken to me at all…
I’ve just installed hestia from built deb packages on a netcup VPS with minimal Ubuntu 20.04. The installation succeded. I just got an email with subject: “OpenSSH restart failed”, but the SSH server was still available.
I even was able to restore an old vesta cp backup on the server including a wordpress site which was working perfectly.
