Debian 12
HestiaCP 1.9.3
When trying to enable plugin File System Disk Quota the following message is returned
Error code: 127
if execute v-add-sys-quota the plugin becomes enabled
if disable the plugin on UI and then try to enable again the following message is shown
/dev/sda1 [/]: group quotas turned on<br>/dev/sda1 [/]: user quotas turned on
but does not show that is enabled
