Hello Guys,
Anyone have experienced this type of issue?
Unable to parse Build/triviaWebGL.framework.js.gz! This can happen if build compression was enabled but web server hosting the content was misconfigured to not serve the file with HTTP Response Header “Content-Encoding: gzip” present. Check browser Console and Devtools Network tab to debug.
If so how did you solved it?
