Hello
I noticed a problem. When the account is stopped on the server, the billing panel sends a request via API to enable the user via v-unsuspend-user
If you go to the panel, you can see that the user is enabled. But the sites still don’t work. I waited a long time. I thought it would turn on automatically after a while. But no
Only service nginx restart helps
What could it be? The same problem with letsencrypt. When a file is generated for confirmation, for some reason nginx does not restart or does not do nginx reload
After executing the command manually, then through the panel, the certificate is issued correctly.
