Updating Debian and keeping locals versions of specific files
Hey,
Just updated Debian that runs HestiaCP. During update process there was couple of popups such as:
Modified configuration file
php.ini: A new version (/usr/lib/php/8.2/php.ini-production) of configuration file /etc/php/8.2/fpm/php.ini is available, but the version installed
currently has been locally modified.
What do you want to do about modified configuration file php.ini?
If I understand logic correctly they should stay the same and HestiaCP will update PHP/Apache/etc itself. All other packages should be updated normally, right?
Just double checking.
yes, never overwrite any configs.
