Hi!
My installation seems to be stuck at 1.9.1
apt update doesn’t find any new version. So… what’s the best way to update?
I’m on Ubuntu 24.04.
Hi!
apt update
apt list --upgradable
root@digioso:\~# apt update
Hit:1 https://deb.nodesource.com/node_22.x nodistro InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports noble-security InRelease
Hit:3 http://eu-frankfurt-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports noble InRelease
Hit:4 http://eu-frankfurt-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports noble-updates InRelease
Hit:5 http://eu-frankfurt-1-ad-1.clouds.ports.ubuntu.com/ubuntu-ports noble-backports InRelease
Reading package lists... Done
Building dependency tree... Done
All packages are up to date.
root@digioso:\~# apt list --upgradable
Listing... Done
root@digioso:\~# cat /etc/\*release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.4 LTS"
PRETTY_NAME="Ubuntu 24.04.4 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.4 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
root@digioso:\~#
You don’t have or don’t have enabled the repositories required by Hestia, show these commands:
ls -la /etc/apt/sources.list.d/
cat /etc/apt/sources.list.d/hestia.list
Oh, thanks!
How do I get the repositories added?
root@digioso:~# ls -la /etc/apt/sources.list.d/
total 52
drwxr-xr-x 2 root root 4096 Aug 25 08:58 .
drwxr-xr-x 8 root root 4096 Feb 4 2025 ..
-rw-r–r-- 1 root root 95 Feb 4 2025 apache2.list.distUpgrade
-rw-r–r-- 1 root root 107 Feb 4 2025 apache2.sources
-rw-r–r-- 1 root root 103 Feb 4 2025 hestia.list.distUpgrade
-rw-r–r-- 1 root root 140 Feb 4 2025 mariadb.list.distUpgrade
-rw-r–r-- 1 root root 121 Feb 4 2025 nginx.list.distUpgrade
-rw-r–r-- 1 root root 100 Feb 4 2025 nodesource.list.distUpgrade
-rw-r–r-- 1 root root 155 Aug 25 08:58 nodesource.sources
-rw-r–r-- 1 root root 173 Feb 4 2025 ondrej-ubuntu-php-jammy.list.distUpgrade
-rw-r–r-- 1 root root 746 Feb 4 2025 ondrej-ubuntu-php-jammy.sources
-rw-r–r-- 1 root root 128 Feb 4 2025 postgresql.list.distUpgrade
-rw-r–r-- 1 root root 416 Feb 4 2025 ubuntu.sources
root@digioso:~# cat /etc/apt/sources.list.d/hestia.list
cat: /etc/apt/sources.list.d/hestia.list: No such file or directory
root@digioso:~#
You must remove or copy those repos removing the .distUpgrade extension:
for f in /etc/apt/sources.list.d/*.distUpgrade; do cp -- "$f" "${f%.distUpgrade}"; done
After that you must check if the release used in that repos is the correct one, in your case, it should be noble, if you came from jammy:
sed -i 's/jammy/noble/g' /etc/apt/sources.list.d/*.list
After that, show again:
apt update
Thanks a lot!
Upgrade was succesfful for the most part. However it seems to have had some trouble with upgrading Roundcube. But I managed to fix that.
