Upgrade to Debian 12 bookworm
I couldn’t find any documentation for the clear path to upgrade from Debian 11 to Debian 12. Debian 12’s been out for some time now. I’m hoping you put together a how to, thank you
I just did the Debian upgrade from 11 to 12 and everything worked fine.
Hi @johnnyz,
Maybe you should modify your exim conf.
ls -l /etc/exim4/srs.conf
grep -ri srs /etc/exim4/exim4.conf.template
If no file found for the first command and no output for the second one, then you should fix your exim conf because you are using the conf for exim 4.94 instead the right one for exim 4.96.
