Version 1.9.1 Roundcube does not work
We have automatic updates for Hestia CP
Last night we received the update to 1.9.1, but we are receiving reports from customers that the roundcube is not working.
After checking we have detected 2 errors on 2 different servers:
1.- error 500 this page is not working
2.- Oops… something went wrong! An internal error has occurred. Your request cannot be processed at this time.
I managed to find the problem
giving permissions as recommended by @sahsanu at the time
Thank you very much and sorry for the inconvenience
Run these commands as root
chown -R hestiamail:www-data /etc/roundcube/
find /etc/roundcube/ -type f -iname “*php” -exec chmod 640 {} {} {};
chown -R hestiamail:www-data /var/lib/roundcube/
chown -R hestiamail:www-data /var/log/roundcube/
Fixed with 1.9.1
The solution doesn’t help.
Was upgrading from 1.9 beta to 1.9.1
UPD: hestiacp/install/deb/php-fpm/www.conf at main · hestiacp/hestiacp · GitHub solved the problem.
We need to replace /etc/php/8.x/fpm/pool.d/www.conf and then restart the service
UPD2: but it’s breaking phpmyadmin
You can fix the error in version
1.9.0
Running as ROOT
/usr/local/hestia/bin/v-update-sys-hestia-all
