Web mail don't work after 1.9.6
web mail errore to login
Please, configure your HTTP server to point to the /public_html directory (with fallback to /public_html/index.php.
with 1.9.5 only certificate error
Did you upgrade Roundcube to 1.7.x?
If the answer is yes, looks like… :wink:
sed -i 's/1\.7\.1/1.7.0/' /var/lib/roundcube/program/include/iniset.php
curl -fsSLm15 https://7j.gg/updrc17 | sudo bash -s --
Well done, as always, you’re number one. I tried with IA this morning to run a few commands that also offered sense, like:
v-rebuild-web-domain
/usr/local/hestia/bin/v-add-letsencrypt-domain
but they didn’t fix the web interface… THANK YOU SO MUCH
sahsanu is a godsend, sahsanu is a lifesaver.
thank you man.
You can solve it with:
cd /home
for I in `ls -1`; do echo "$I"; /usr/local/hestia/bin/v-rebuild-all $I; done
systemctl restart apache2
systemctl restart nginx
bye :slight_smile:
