Keep local version installed…
okay, thanks bro
If you don’t keep the local config things will break
I’m partial to comparing the contents of the versions. If the new version introduces any important changes, you can then merge the prior customization into the new version. This allows for the relevant updates without breaking the current configuration. If you don’t want to invest the time to diff and merge, keeping the current configuration is safest.
