I need to re-install hestiacp on my server. But I already added about 300 domains and same number of databases. Will they all be vanished if I do the re-installation?
Many thanks,
Simar
Many thanks,
Simar
There should be no reason to reinstall hestiacp, if you have an issue, you need to fix that - reinstall is mostly useless. If you want to do a clean reinstall, you need to wipe your server/os completly, then start from zero. You can backup your data with v-backup-user(s) and move it prior to the wipe, then restore it with v-restore-user.
