Wordpress not sending emails
Sorry if I take up this speech.
To get the mail out of wordpress only (for example from a contact page or other form) do I have to leave exim4 installed on the server?
I would like to install hestia without internal mail management, so no rondcube. But to work only with the amazon workmail, but I have to get the emails out of wordpress.
Thank you all.
Basicly you can also set a remote smtp for wordpress or also provide a local mta, which automatically relays the email sent to localhost port 25 (from localhost only) to a external smtp gateway. There is no direct need to install exim, but it makes the life easier :slight_smile:.
Thanks @Raphael
So in theory I can do without installing both exim and dovecot and leave everything to a Wordpress SMTP plugin, like fluentSMTP for example
did I get it right? thank you very much
Yeah, you got it right.
You can do that, and in fact that is what I do, but I leave exim so that I have a Plan B in case things go south.
Thanks guerrero,
I will do as you say, but dovecot and rondcube I can take them off
And spam assassin and clamav
