jobet
October 31, 2021, 6:04pm
#1
I have a WordPress site domain.tld and everything is working fine.
However when I type www.domain.tld the request times out…
Looking up in the Nginx conf file, the server_name directive in the http server block seems fine:
server_name: domain.tld www.domain.tld;
ScIT
October 31, 2021, 6:16pm
#2
Way more to check, is dns running and pointing to the right ip?
jobet
October 31, 2021, 6:25pm
#3
Yes, DNS records are in Cloudflare, and there’s a CNAME record for www host
jobet
October 31, 2021, 6:31pm
#4
BTW the “Enable domain redirection” is enabled in HestiaCP with the option “Redirect visitors to domain.tld” option…
eris
October 31, 2021, 7:21pm
#5
Without more information I have no idea…
jobet
October 31, 2021, 10:10pm
#6
@eris which further information do you need?
jobet
November 1, 2021, 2:30pm
#7
@eris how can I troubleshoot this?
eris
November 1, 2021, 3:15pm
#8
Error logs of the domains and so on
jobet
November 1, 2021, 5:00pm
#9
Found the problem… it was a cloud-based firewall in front of the server that was blocking something…
Maybe something related to DNS resolution? Port 53 (TCP/UDP) is opened in the firewall… and DNS resolution (dig google.com ) is working fine…
Is there any other port I should open?
jobet
November 1, 2021, 5:05pm
#10
Found the culprit… the firewall had restriction access rules to HTTP and HTTPS ports.
Setting any IP (0.0.0.0/0) as source IPs solves the problem…
system
closed
December 1, 2021, 5:06pm
#11
