1.10.6 Stuck on Upgrading Roundcube
Trying to update im on Ubuntu 24.04
but stuck here for at least 10 mins now this happened last time I ctrl ced and had to run dpkg -a configure to fix
[ ! ] IMPORTANT INFORMATION:
Default configuration files and templates may be modified or replaced
during the upgrade process. You may restore these files from:
Backup directory: /root/hst_backups/061120262038/
Installation log: /root/hst_backups/061120262038/hst-upgrade-061120262038.log
[ * ] Backing up existing templates and configuration files…
[ ! ] Performing system health check before proceeding with installation…
[ * ] Health check complete. Starting upgrade from 1.10.5 to 1.10.6…
[ - ] Now applying patches and updates for version v1.10.6…
[ + ] Adding support for custom DKIM selector in Exim
[ + ] Exim4 restarted successfully with custom DKIM selector support
[ + ] Allowing unattended-upgrades to install PHP updates
[ + ] Allowing unattended-upgrades to install nginx updates
[ + ] Fixing PhpMyAdmin SSO config…
[ + ] Allowing unattended-upgrades to install MariaDB updates
[ + ] Allowing unattended-upgrades to install Node.js updates
[ + ] Trimming whitespace from web domain IP addresses
[ + ] Allowing unattended-upgrades to install PostgreSQL updates
[ + ] Fixing Exim HELO checks
[ + ] Backup created: /etc/exim4/exim4.conf.template.20261106-203852.acl_check_mail.bak
[ + ] Exim replacement done successfully
[ + ] Regenerating configuration and restarting Exim
[ + ] Exim restarted successfully with the new configuration
[ + ] Updating phpMyAdmin nginx configuration
[ + ] Allowing unattended-upgrades to install Apache updates
[ ! ] Upgrading File Manager to version 7.16.9…
[ ! ] Upgrading Roundcube to version 1.7.5…
Progress: [ 60%] [#########################################################################################################################…]
so whiles its stuck here I was able to access roundcube mail and when I hit about looks like it upgraded to 1.7.5 yet its still stuck at updating
Type yes and press Enter to continue the installation.
Related post: Upgrade 1.10.6 error, do I need to type 'yes' manually for it to proceed?
I did a ctrl z which broke out prolly means its putting in the background task because I see task like rebuilding domains under ps -axu so ill let it ride out
Thanks for your quick response @sahsanu
Okay so here what I did after no more rebuilds were coming on ps-axu I killed -9 dpkg did a dpkg -a --configure and it ran through again as normal now im updated.
I know for the in the future that ill have type yes then enter since it was hiding
In the future that shouldn’t happen again :wink:
