Hello everyone. Development for 1.4.0 is hopefully coming to an end and for that before we release it to everybody we would like input from more users than only the development team.
Warning: This is an BETA build. Please do not install this package on production systems as it might break current systems! And try it out on a test server that may break if something went wrong.
To install the package:
# Change to root home or any other directory
cd /root
# Download the precompiled packages
wget https://apt.hestiacp.com/beta/hestia_1.4.0~alpha_amd64.deb
# Now install the hestia package
dpkg -i hestia_1.4.0~alpha_amd64.deb
# Cleanup
rm hestia_1.4.0~alpha_amd64.deb
Biggest changes:
- Improvement to webmail stack add the possibility to add Rainloop ( hestiacp/v-add-sys-rainloop at main · hestiacp/hestiacp · GitHub)
- Disconnect Roundcube from atp. We will install Roundcube directly from source. (hestiacp/migrate_roundcube.sh at main · hestiacp/hestiacp · GitHub)
- Disconnect PHPmyadmin from atp hestiacp/migrate_phpmyadmin.sh at main · hestiacp/hestiacp · GitHub
- PHPmyadmin Single Sign On.
Please make sure api is enabled and the hestiacp/v-add-sys-pma-sso at main · hestiacp/hestiacp · GitHub - Added support for Nginx Change Fast CGI
- Added an SMTP Relay support for the whole server aswell for each domain.
For a full change log please check:
Please report any issue/error you find on the Forum, Discord or Github
