1.9.31.9.3 language problems
Hello. After updating to version 1.9.3, the language settings have disappeared
Russian and Ukrainian are not used. It also does not work through the console. What should I do?..
Problem on ubuntu 22.04
I haven’t updated servers with debian 12 yet.
If system wide, use v-change-sys-language, and if limited to a user use v-change-user-language.
Example: v-change-sys-language ru / v-change-user-language admin en
Update: check for your system available languages via v-list-sys-languages
None of this works. (
what is the output or error if any?
I have 0 issues …
Tested on both 22.04 and 24.04
I do the same. And I checked the box to apply to all. It doesn’t work. Before the update everything was fine.
Any errors
Is the en_US locale installed on the server?
It’s funny, of course. I delivered en_US.utf8 and it worked. Very strange. This is an Oracle server. It worked somehow before the update. I don’t understand.
Manual:
apt install -y locales
locale-gen en_US.UTF-8
update-locale LANG=en_US.UTF-8
source /etc/default/locale
reboot
