Debian 12.10
When backing up the server, it seems to help to stop Exim and Dovecot. I’ve been using Hestia to do this: I click on the “gear” for Server Settings, check the box for each server, then Apply to selected: Stop. Ever since around v1.9.1, Hestia comes back with 1 red X and one green check. It looks to me like both servers get stopped, so it is only the green indicator that is goofy.
I had added a new web (sub)domain without enabling Web Statistics. I cannot find a checkbox to do that now, but I did find v-add-web-domain-stats but it tells me Error: invalid user format :: validusername
It works fine on my test server. When the services are up and running, check the status:
systemctl status exim4 --no-pager -l
systemctl status dovecot --no-pager -l
Now stop both services from Web UI and check again the services:
Also check the Hestia’s log.
tail -n 20 /var/log/hestia/{error.log,system.log}
It’s not a check box but a dropdown menu.
v-list-sys-config json | jq -r '.[]|.STATS_SYSTEM'
I forgot to ask.
What’s the exact command that you’re using? I’m insterested in the username you’re using.
tried admin, just to check; returns the same errmsg as woze
v-add-web-domain-stats admin sub.domain.tld awstats
DUH/OOPS , thank you very much .
Works great, I think: Saved ok, including authentication, but the screen tells me “If the aliases changes, Let’s Encrypt will obtain a new SSL certificate.” but doesn’t tell me where to go to find any stats. (/stats and /awstats don’t work), so I got distracted before giving up for now.
I’ll have to get back to you on the rest of your much-appreciated reply…
It’s /vstats/ (the last slash is important).
https://example.com/vstats/
Thank you again very much. (I love examples…)
root@s41:~# systemctl status exim4 --no-pager -l
● exim4.service - LSB: exim Mail Transport Agent
Loaded: loaded (/etc/init.d/exim4; generated)
Active: active (running) since Sat 2025-03-29 06:15:55 EDT; 1 week 0 days ago
Process: 2330067 ExecStart=/etc/init.d/exim4 start (code=exited, status=0/SUCCESS)
Process: 3553437 ExecReload=/etc/init.d/exim4 reload (code=exited, status=0/SUCCESS)
Tasks: 2 (limit: 2228)
Memory: 31.4M
CPU: 3min 36.546s
CGroup: /system.slice/exim4.service
├─2330315 /usr/sbin/exim4 -bd -q30m
└─3700473 /usr/sbin/exim4 -bd -q30m
Apr 02 06:14:03 s41.mydomain.com systemd[1]: Reloaded exim4.service - LSB: exim Mail Transport Agent.
Apr 03 06:14:04 s41.mydomain.com systemd[1]: Reloading exim4.service - LSB: exim Mail Transport Agent...
Apr 03 06:14:04 s41.mydomain.com exim4[3201214]: Reloading exim4 configuration files: exim4.
Apr 03 06:14:04 s41.mydomain.com systemd[1]: Reloaded exim4.service - LSB: exim Mail Transport Agent.
Apr 04 06:14:04 s41.mydomain.com systemd[1]: Reloading exim4.service - LSB: exim Mail Transport Agent...
Apr 04 06:14:04 s41.mydomain.com exim4[3378572]: Reloading exim4 configuration files: exim4.
Apr 04 06:14:04 s41.mydomain.com systemd[1]: Reloaded exim4.service - LSB: exim Mail Transport Agent.
Apr 05 06:14:04 s41.mydomain.com systemd[1]: Reloading exim4.service - LSB: exim Mail Transport Agent...
Apr 05 06:14:04 s41.mydomain.com exim4[3553437]: Reloading exim4 configuration files: exim4.
Apr 05 06:14:04 s41.mydomain.com systemd[1]: Reloaded exim4.service - LSB: exim Mail Transport Agent.
root@s41:~# systemctl status dovecot --no-pager -l
● dovecot.service - Dovecot IMAP/POP3 email server
Loaded: loaded (/lib/systemd/system/dovecot.service; enabled; preset: enabled)
Docs: man:dovecot(1)
https://doc.dovecot.org/
Process: 3553335 ExecReload=/usr/bin/doveadm reload (code=exited, status=0/SUCCESS)
Main PID: 2330010 (dovecot)
Status: "v2.3.19.1 (9b53102964) running"
Tasks: 6 (limit: 2228)
Memory: 16.2M
CPU: 16min 27.971s
CGroup: /system.slice/dovecot.service
├─2330010 /usr/sbin/dovecot -F
├─2330013 dovecot/anvil
├─3553392 dovecot/log
├─3553801 dovecot/config
├─3553802 dovecot/stats
└─3553804 dovecot/auth
Apr 01 06:14:03 s41.mydomain.com systemd[1]: Reloading dovecot.service - Dovecot IMAP/POP3 email server...
Apr 01 06:14:03 s41.mydomain.com systemd[1]: Reloaded dovecot.service - Dovecot IMAP/POP3 email server.
Apr 02 06:14:03 s41.mydomain.com systemd[1]: Reloading dovecot.service - Dovecot IMAP/POP3 email server...
Apr 02 06:14:03 s41.mydomain.com systemd[1]: Reloaded dovecot.service - Dovecot IMAP/POP3 email server.
Apr 03 06:14:04 s41.mydomain.com systemd[1]: Reloading dovecot.service - Dovecot IMAP/POP3 email server...
Apr 03 06:14:04 s41.mydomain.com systemd[1]: Reloaded dovecot.service - Dovecot IMAP/POP3 email server.
Apr 04 06:14:03 s41.mydomain.com systemd[1]: Reloading dovecot.service - Dovecot IMAP/POP3 email server...
Apr 04 06:14:03 s41.mydomain.com systemd[1]: Reloaded dovecot.service - Dovecot IMAP/POP3 email server.
Apr 05 06:14:04 s41.mydomain.com systemd[1]: Reloading dovecot.service - Dovecot IMAP/POP3 email server...
Apr 05 06:14:04 s41.mydomain.com systemd[1]: Reloaded dovecot.service - Dovecot IMAP/POP3 email server.
○ exim4.service - LSB: exim Mail Transport Agent
Active: inactive (dead) since Sun 2025-04-06 03:28:45 EDT; 20s ago
Duration: 1w 21h 12min 49.228s
Process: 3700769 ExecStop=/etc/init.d/exim4 stop (code=exited, status=0/SUCCESS)
Tasks: 1 (limit: 2228)
Memory: 30.8M
CPU: 3min 36.572s
Apr 06 03:28:45 s41.mydomain.com systemd[1]: Stopping exim4.service - LSB: exim Mail Transport Agent...
Apr 06 03:28:45 s41.mydomain.com exim4[3700769]: Stopping MTA: exim4_listener.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: exim4.service: Deactivated successfully.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: exim4.service: Unit process 3700473 (exim4) remains running after unit stopped.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: Stopped exim4.service - LSB: exim Mail Transport Agent.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: exim4.service: Consumed 3min 36.572s CPU time.
○ dovecot.service - Dovecot IMAP/POP3 email server
Active: inactive (dead) since Sun 2025-04-06 03:28:45 EDT; 26s ago
Duration: 1w 21h 12min 48.191s
Process: 2330010 ExecStart=/usr/sbin/dovecot -F (code=exited, status=0/SUCCESS)
Process: 3700714 ExecStop=/usr/bin/doveadm stop (code=exited, status=0/SUCCESS)
Main PID: 2330010 (code=exited, status=0/SUCCESS)
Status: "Dovecot stopped"
CPU: 16min 28.057s
Apr 06 03:28:43 s41.mydomain.com systemd[1]: Stopping dovecot.service - Dovecot IMAP/POP3 email server...
Apr 06 03:28:45 s41.mydomain.com systemd[1]: dovecot.service: Deactivated successfully.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: Stopped dovecot.service - Dovecot IMAP/POP3 email server.
Apr 06 03:28:45 s41.mydomain.com systemd[1]: dovecot.service: Consumed 16min 28.057s CPU time.
Since this is a public forum, I hope you don’t mind tooo much that I’m anonymizing the entries:
==> /var/log/hestia/error.log <==
2025-04-04 03:43:20 v-list-dns-domain 'woze' 'webmail.sub.domain.tld' 'plain' [Error 3]
2025-04-04 03:43:20 v-add-dns-domain 'woze' 'webmail.sub.domain.tld' 'nn.nnn.nnn.nn' 'ns1.domain.tld' 'ns2.domain.tld' '' '' '' '' '' '' 'no' 'no' [Error 2]
2025-04-05 03:32:25 v-add-web-domain-stats '' [Error 1]
2025-04-05 03:33:01 v-add-web-domain-stats 'woze' 'sub.domain.tld' 'awstats' [Error 2]
2025-04-05 03:41:09 v-add-web-domain-stats 'woze' 'sub.domain.tld' 'awstats' [Error 2]
2025-04-05 03:47:23 v-add-web-domain-stats 'woze' 'sub.domain.tld' 'awstats' [Error 2]
2025-04-05 03:52:43 v-add-web-domain-stats 'woze' 'domain.tld' 'awstats' [Error 2]
2025-04-05 03:52:53 v-add-web-domain-stats 'woze' 'sub.domain.tld' 'awstats' [Error 2]
2025-04-05 03:53:29 v-add-web-domain-stats 'admin' 'sub.domain.tld' 'awstats' [Error 2]
==> /var/log/hestia/system.log <==
2025-04-06 02:15:04 v-update-mail-domains-disk 'username1'
2025-04-06 02:15:04 v-update-databases-disk 'username1'
2025-04-06 02:15:04 v-update-user-disk 'domain1.com'
2025-04-06 02:15:04 v-update-web-domains-disk 'domain1.com'
2025-04-06 02:15:05 v-update-mail-domains-disk 'domain1.com'
2025-04-06 02:15:05 v-update-databases-disk 'domain1.com'
2025-04-06 02:15:05 v-update-user-disk 'username2'
2025-04-06 02:15:05 v-update-web-domains-disk 'username2'
2025-04-06 02:15:05 v-update-mail-domains-disk 'username2'
2025-04-06 02:15:05 v-update-databases-disk 'username2'
2025-04-06 02:15:05 v-update-user-disk 'domain2.com'
2025-04-06 02:15:05 v-update-web-domains-disk 'domain2.com'
2025-04-06 02:15:05 v-update-mail-domains-disk 'domain2.com'
2025-04-06 02:15:05 v-update-databases-disk 'domain2.com'
2025-04-06 03:25:55 v-add-firewall-chain 'MAIL'
2025-04-06 03:25:55 v-add-firewall-ban '211.186.220.42' 'MAIL'
2025-04-06 03:28:45 v-stop-service 'dovecot'
2025-04-06 03:28:45 v-stop-service 'exim4'
2025-04-06 03:29:28 v-start-service 'dovecot'
2025-04-06 03:29:28 v-start-service 'exim4'
# v-list-sys-config json | jq -r '.[]|.STATS_SYSTEM'
awstats
but that’s after I used the oh-look-at-that drop-box to enable it…
FWIW, since the previous time I started a thread here, I scrapped the Debian 11 system that had become a little questionable, and started over from scratch last year with Deb12. The system seems a-ok (but what do I know?). The goofy green indicator is the only anomaly I’ve noticed, and it began occurring several Hestia revisions ago.
Exim4 service is stopped but the main process is not.
Hestia is still detecting this Exim4 process and it marks the service as running.
I don’t know the reason Exim4 is not stopping, you could check the exim4 logs.
Try to stop it again:
systemctl stop exim4
If it’s still running, kill the process (check that 3700473 is the pid for the current exim4 process) :
kill 3700473
or
kill -9 3700473
Thank you once again. fwiw, ~weirdness w/apparent success:
sahsanu:
root@s41:~# systemctl stop exim4
Active: inactive (dead) since Sun 2025-04-06 17:50:02 EDT; 4s ago
Duration: 14h 20min 34.678s
Process: 3701272 ExecStart=/etc/init.d/exim4 start (code=exited, status=0/SUCCESS)
Process: 3727848 ExecReload=/etc/init.d/exim4 reload (code=exited, status=0/SUCCESS)
Process: 3803216 ExecStop=/etc/init.d/exim4 stop (code=exited, status=0/SUCCESS)
Memory: 27.3M
CPU: 24.853s
└─3802822 /usr/sbin/exim4 -bd -q30m
root@s41:~# kill 3802822
-bash: kill: (3802822) - No such process
root@s41:~# ps -e | grep exim4
Active: inactive (dead) since Sun 2025-04-06 17:50:02 EDT; 1min 0s ago
CPU: 24.868s
(zero uptime for iptables always seems to be the norm[?])
not sure how much diff it might make, but it seems like my mail server is under near-constant bombardment (~100 bogus queries per second) from the same IPaddr show up in /var/log/exim4/rejectlog, then again from a different IPaddr seconds later (with no overlap), usually blacklisted by spamcop/spamhaus but still logged, and ignored by fail2ban) by 1 or more bot armies.
permaban (thank you!) helps some, but it’s ~impossible to keep up…
Welcome to the grand adventure of hosting your own mail server
Are you using any block list? I recommend to add at least the block list script provided by Hestia (/usr/local/hestia/install/common/firewall/ipset/blacklist.sh) as the source of an ipset. Once done, add a firewall rule to DROP all traffic from that ipset.
I used Hestia webUI /list/firewall/ipset to “Add IP list”, named it “blacklist”, selected it from top of pull-down menu, Saved… .
Not being sure how to do that (I love eamples…), I found past primo instructions for permaban , but thought it would be a good idea to check back w/you before trying to follow instruction. My guess:
# v-add-firewall-rule DROP ipset:blacklist 0 TCP "BLACKLIST"
yes?
Yes, that’s correct.
You can also add it via the Web UI:
So, I did the CLI, seemed fine, but to complete my learning experience I decided to see the Web UI, BUT IT WILL NOT LOAD IN MY BROWSER! NO HESTIACP PAGES WILL! The connection (attempt) times out.
Since my connnections come from a shared cloud exit point (Tor), that’s not totally inexplicable. But it might make this solution unusable for me.
WORSE, I find myself unable to fix it:
root@s41:~# v-add-firewall-rule DROP ipset:blacklist 0 TCP “BLACKLIST”
root@s41:~# v-list-firewall-rule 2
Error: invalid rule id format :: 2
root@s41:~# v-list-firewall-rule BLACKLIST
Error: invalid rule id format :: BLACKLIST
root@s41:~# v-list-firewall-rule blacklist
Error: invalid rule id format :: blacklist
root@s41:~# v-delete-firewall-rule BLACKLIST
root@s41:~# v-delete-firewall-rule blacklist
root@s41:~# v-delete-firewall-rule ipset:blacklist
Error: invalid rule id format :: ipset:blacklist
Show the output of v-list-firewall
RULE ACTION PROTO PORT IP SPND DATE
1 ACCEPT ICMP 0 0.0.0.0/0 no 2014-09-16
2 ACCEPT TCP 8888 0.0.0.0/0 no 2014-05-25
3 ACCEPT TCP 143,993 0.0.0.0/0 no 2014-05-25
4 ACCEPT TCP 110,995 0.0.0.0/0 no 2014-05-25
5 ACCEPT TCP 25,465,587 0.0.0.0/0 no 2018-11-07
6 ACCEPT TCP 53 0.0.0.0/0 no 2014-05-25
7 ACCEPT UDP 53 0.0.0.0/0 no 2014-05-25
8 DROP TCP 21,12000-12100 0.0.0.0/0 no 2024-12-20
9 ACCEPT TCP 80,443 0.0.0.0/0 no 2014-09-24
10 ACCEPT TCP 7777 0.0.0.0/0 no 2014-09-16
11 DROP TCP 0 ipset:permaban no 2024-10-30
12 DROP TCP 0 ipset:blacklist no 2025-04-06
v-delete-firewall-rule 12
