2FA QR code panel name customization
Hi there,
I’m wondering if it’s possible to change the issuer name in the QR code when setting up 2FA. Currently, it shows:
issuer=Hestia%20Control%20Panel&period=30&algorithm=SHA1&digits=6
Is there a way to customize this?
Thanks for your help!
You can modify:
$tfa = new TwoFactorAuth("Hestia Control Panel");
on both files:
/usr/local/hestia/web/inc/2fa/check.php
/usr/local/hestia/web/inc/2fa/secret.php
But that modification will be replaced on next update.
