Hi
Hestia 1.7.7 on Ubuntu 20.04 running nginx
I need to 301 redirect requests from http://example.com to https://example.com - including any file/directory requests.
I have tried using the checkbox in Hestia CP with no success
I have tried creating a file: /home/xadmin/conf/web/example.com/nginx.conf_redirect_rules
with content:
# Redirect Configuration:
server {
listen 80;
server_name *.example.com example.com;
return 301 https://$host$request_uri;
no success
I have tried creating a template: /usr/local/hestia/data/templates/web/nginx/redirect_rule.tpl
with content:
server {
listen 80 default_server;
server_name _;
No success
I have restarted nginx each time, even restarted hestia… no success.
I’m not sure either the content of these files nor the location is 100% correct, but I have tried!
Could someone help please?
I ended up editing /etc/nginx/conf.d/domains/example.com.conf and adding:
server {
listen 80;
server_name example.com;
at the end of the file.
I finally have cURL response:
HTTP/1.1 301 Moved Permanently
Server: nginx
Date: Wed, 31 May 2023 15:00:11 GMT
Content-Type: text/html
Content-Length: 162
Connection: keep-alive
eris
3
Will get overwritten during next upgrade…
How do I prevent it getting overwritten during next upgrade?
eris
5
Create a template for it:
I did that originally, with no effect. I’ve done it again, still no effect.
file: /usr/local/hestia/data/templates/web/new_default.tpl
Contents:
server {
listen 80;
curl -I http://example.com
response:
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 01 Jun 2023 13:28:56 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 3231
Last-Modified: Wed, 31 May 2023 09:20:17 GMT
Vary: Accept-Encoding
ETag: "64771151-c9f"
Accept-Ranges: bytes
Is the template being loaded? Do I need to do anything else to make it load?
eris
7
Did you update in the domain selection → template it should work fine
there is no option for the new template in domain selection
eris
9
You need create /usr/local/hestia/data/templates/web/nginx/php-fpm/new_default.tpl
Thanks Eris.
I created /usr/local/hestia/data/templates/web/nginx/php-fpm/new_default.tpl
with total content:
server {
listen [::]:80;
and after restarting nginx and hestia, new_default appears in the drop down list, but now I get this when I save the domain edit page:
Should I copy default.tpl and append my server block, or is simply creating a new file with that block sufficient?
eris
11
You need to create both .stpl and tpl file
oh ok, so the list of files I need to create would be:
/usr/local/hestia/data/templates/web/nginx/new_default.tpl
/usr/local/hestia/data/templates/web/nginx/new_default.stpl
/usr/local/hestia/data/templates/web/nginx/php-fpm/new_default.stpl
and the content in all those files would be:
server {
listen [::]:80;
is that correct?
[edit]
If I add a 301 to https in the .stpl files, won’t that cause an infinite loop?
eris
13
You need for the default.stpl use default.stpl contents …
That makes more sense, thanks
so now I have:
with contents:
server {
listen [::]:80;
and /usr/local/hestia/data/templates/web/nginx/new_default.stpl
which is a copy of /usr/local/hestia/data/templates/web/nginx/default.stpl
and /usr/local/hestia/data/templates/web/nginx/php-fpm/new_default.stpl
which is a copy of /usr/local/hestia/data/templates/web/nginx/php-fpm/magento.stpl
(copying default.tpl broke Magento).
I have set the domain template to new_default, restarted nginx and hestia
BUT
Still no redirect from http to https
Do you have any more ideas?
system
Closed
15
