504 Gateway error timeout
hello, guys i am using an application call vtiger, however time to time it become very slow when loading and then
“The gateway did not receive a timely response from the upstream server or application.”
i read i have to change max time outs. where is that on UI? cant find it. thanks (once again new to hestia)
Check /etc/apache2/apache2.conf / /etc/nginx/nginx.conf via CLI
so there is no way to do it with the UI?
No, only over cli.
ok, thanks
Yes!
Under the advanced options you can edit the file via UI.
https://my.hestiaserver.com:8083/edit/server/nginx/
