525 handshake error cloudflare/letsencrypt
Hello, i get this error from time to time, lat for few minutes then everything is fine.
i use nginx with php fpm. domain and server using letsencrypt and in cloudfare set to SSL full mode.
never had this issue with vestacp and same nginx-phpfpm.
any idea?
See https://community.cloudflare.com/t/community-tip-fixing-error-525-ssl-handshake-failed/44256
Currently use the same setup with out any issues …
Thanks, i was not able to find any error in logs after having the issue, i dont know about the chiper, i checked in nginx and it looks like they are all there?
I get this random and my uptime monitor tells me, site works 99% of the time but then i have this error random
Hi @habashini,
You can try using the Cloudflare Origin Certificate instead of Letsencrypt one to check if it resolves the error for you.
See https://docs.hestiacp.com/admin_docs/ssl_certificates.html#can-i-use-a-cloudflare-origin-ssl-certificate-with-cloudflare
