7G/8G firewall on Hestia
To enhance the web security, I’ve done with firewall, fail2ban here which working well by Hestia itself. This makes network layer a bit safer.
Next level will be the application level, I am trying to do it with WAF. There are many options for this, Cloudflare, Mod_security (with OWASP rules set), and some other vendors online WAF (mostly paid), and 7G/8G firewall (7G Firewall for Nginx | Perishable Press)
Mod_Security → This is far too complicated for my tech level, and as research from web, it takes months to fine tune acceptable setup.
Cloudflare → This is all-in-one solution which also help for CDN, looks very perfect. However, my site occasionally require upload files larger than 100Mb, which is restricted by Cloudflare..
Other online WAF → Don’t want to pay for just my personal website. Maybe someone can suggest free reputable online WAF?
Final one is what I am trying now, 7G/8G firewall by https://perishablepress.com
→ This is easy to apply on Nginx level (as reading from someone posted earllier), just put the files to respective location and restart Nginx, then it works right away.
However, I find out 8G is very restrictive which blocked phpinfo, and my site keyboard shortcut (Ctrl+Enter to submit post) also blocked.
7G is working better and so far I didn’t face any issue with my website.
Just want to have your experience on how do you guys deploy WAF on your Hestia build? or just rely on network layer protection (fail2ban, firewall)?
By any chance are you using WordPress? If yes - I would recommend using Ninja Firewall plugin. Other than that - you can also look into self hosting this WAF - GitHub - chaitin/SafeLine: SafeLine is a self-hosted WAF(Web Application Firewall) / reverse proxy to protect your web apps from attacks and exploits.
I am not using Wordpress, reading the Safeline but may I know how did it work and integrate with Hestia?
Is it Safeline just as a seperate docker app. I put my domain to there once I’ve setup?
One more thing, I only use one single VPS, I think Safeline maybe too heavy as to host on the same server together with my Hestia and Webserver?
Modern software should be using chunked uploads making this a non-issue. Just make sure the chunk sizes remain below 100 MB.
It might be better to use IP List + nginx-ultimate-bad-bot-blocker. CF is good, but it slows down during rush hours.
I think this is more on IP filtering but what I’d like to explore is about WAF whcih protect me if my web script suddenly exposed with security breaach
Hello, and please excuse my English.
I am developing a plugin that facilitates installation and configuration within HestiaCP.
It includes the official “8G” rules, along with some modifications based on our own field analysis.
It also features centralized analysis logs (or logs broken down by domain, etc.).
So far, testing has been conducted on Debian 13 and HestiaCP 1.10.9, using Apache2.
I expect everything to be made public on our Git repository by the end of the year.
Very interesting; it would be great if they officially integrated it into HestiaCP.
