How can I make the ‘Server information’ appear on my website? Right now, it doesn’t appear, possibly due to permissions.
My website:
https://server.loleuw.com/
Script:
My website:
Script:
You need to remove exec function from disable_functions directive inside php.ini conf file.
If you are using PHP 8.2 then you should remove it like this:
sed -i -E 's/(^disable_functions.*),exec(.*$)/\1\2/' /etc/php/8.2/fpm/php.ini
And after that, restart php service:
systemctl restart php8.2-fpm
Keep in mind that allowing exec function could be a security risk so remove it at your own risk.
Thanks for the response. Can I turn it off just for a specific website? So I don’t mess up the security for everything else.
No… Only server overall…
