Is it possible for Hestia to overwrite the original file with the same name when uploading the file?
You mean with the file manager? I suppose so.
Yes, that means a file manager.
Okay, go to your domain’s public_html folder and create or upload test.txt with the following content:
“The contents are not overwritten”
Then create a new test.txt in your computer with the following text:
“The contents are overwritten”
Then copy the second test.txt into the public_html folder and then see what happens.
Even if I made test.txt and wrote “The contents are overwritten” and uploaded it, the file could not be overwritten.
I may have misunderstood something.
I am sure you can’t just overwrite a already existing text file. Only editing is allowed…
Can’t I upload a file and overwrite it?
Apparently not but you may connect via SFTP.
I guess that if you unzip a file the files will be overwritten. You can test it the same way I told you before.
No in the filemager it checks if the file exists and probably not overwrite probably a limitations for the file manger.
I was able to connect from SFTP using my username, and I’ll be able to overwrite the file.
Thank you very much. I will also use SFTP.
Is there a config file where we can change the default behavior?
I don’t know…
