ACME files are not created
Hi
I am using the control panel to renew the SSL certificates for my email domains but it is failing with the error shown in the image.
The ACME directory is accessible and writeable so the problem must be that a process is failing to create them.
I have done lots of trouble shooting but to no avail
Did the DNS propagate yet? Check that.
Also, check all the DNS entries too, something maybe amiss.
Possible to share your domain name, so that we can check it for DNS propagation as well?
Meanwhile, also try to add via CLI: CLI Reference | Hestia Control Panel
v-add-mail-domain-webmail user domain.com
example: v-add-mail-domain-webmail user domain.com snappymail
example: v-add-mail-domain-webmail user domain.com roundcube
DNS is fine. Was done days ago and they resolve fine.
gives:
Error: snappymail type is invalid
Hi @kpop1
Hestia doesn’t create any file for the acme challenge so you don’t need to create .well-known/acme-challenge dirs under your public_html.
To debug it, it’s important to share the actual domain name.
I am maintaining privacy by not disclosing domain names.
Hestia is “work in progress” and I need to know what files are expected to be in the acme-challenge dir and I will create them with the expected contents. I am not new to either linux or software development. I even obtained certificates with certbot but they were missing the .ca filewhich Hestia expects in the backend textarea field
We create a nginx config that emulates the file it should work fine.
Check if http://domain.com/ is loading the under construction page and not the “success” page
No it does not. It shows “Success”. Like nginx is not redirecting to the software cgi-bin dir and it’s just the standard Successful server install page
By accident multiple ips on the server?
systemctl restart nginx working?
When I do it, yes. I even rebooted server in my “agony”.
This is an AWS instance so I think there is a private IP and public IP from the pool of Amazon addresses which I’ve reserved. But this hadn’t caused any problem in a past install
Check your ip in web settings it should be your public ip
