I will install Hestiacp from Comamnd below
sudo bash hst-install.sh --apache no --nginx yes --phpfpm yes --multiphp yes --vsftpd yes --proftpd no --named yes --mysql yes --postgresql no --exim yes --dovecot yes --clamav no --spamassassin yes --iptables yes --fail2ban yes --quota no --api yes --force no --interactive yes --port 8083 --lang en
I want to know
–api Activate API
–interactive interactive install
What’s going on with these?
Remove them?
eris
June 16, 2020, 1:53am
2
API Access allow you to modify certain things via command line
For example add a user, create a database or modify a DNS record It is also used for syncing DNS records between 2 Hestia Servers
Interactive install will give u option to set email adress, host name during the install if it has not been set via command line and skips multiple checks…
See https://docs.hestiacp.com/getting_started.html#all-available-options-of-install-script for more info
Gras
June 28, 2020, 7:05pm
3
is there possibility to add packages via API after main Hestiacp instalation.
I have installed the default packages with main installation. Now i would like to add postgre, what is the best proceedure?
thanj you
eris
June 28, 2020, 7:20pm
4
Nope, not yet it is in the planning for the future
You could follow the steps used in the install script
Or follow the steps from the VestaCP docs
https://vestacp.com/docs/#how-to-setup-postgresql-debian-ubuntu
But replace the config files in usr/local/hestia/install/deb/postgresql/
And install phppgadmin from atp
