Hola , tengo 3 servidores con hestia panel, uno me da el siguiente error
Error: hestia update failed
Error: hestia-nginx update failed
Error: hestia-php update failed
Gracias
Gracias
Apt update
Apt upgrade
The apt upgrade fails
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
Optios:
Configuration file ‘/etc/apache2/ports.conf’
==> Modified (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer’s version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** ports.conf (Y/I/N/O/D/Z) [default=N] ?
I put Y and the sites gave me error 502
I need help
why you put yes? use the search function, has been handöed a lot of times, you’ll find how to restore both needed config files.
Since the critical files that should never be touched are known, maybe hestiaCP could keep a backup of those and we could have a script to restore config to hestia defaults.
We do have allready a backup in place (At least if you have update the last backup)
Ok Thanks
Very good instructive, I was able to solve it. Thank you
