Add another domain in the running website
Hi
We are currently operating the site on abc.com. We want to change the site name to 123.com.
For testing purposes, we would like to attach the 123.com domain to the abc.com site. It’s not a redirection. In other words, abc.com/test.php and 123.com/test.php should point to the same file.
How can we set up the 123.com domain? DNS settings have been completed. Should we change the virtual host? Where is this file located? Is there a way to do this in Hesitacp?
Just add 123.com as alias of abc.com
Thank you for your reply. If possible, could you provide tips on how to do it in HesitaCP?
I’ve added 80000.or.kr and www.80000.or.kr in the Aliases but I connect to the 80000.or.kr. I just see the magazinet.co.kr not 80000.or.kr
Is there any other way to do ?
Hi @hotelier,
Disable domain redirection.
Thank you very much.
