Add basic auth to all newly created sites by default
I am using the wonderful hestia control panel for the development purposes. So I not to forget to change robots.txt each time I create a copy of a site. I would like to automate this somehow. More to that, I do not want accidentally commit those temporary changes in git.
Putting all the sites under a basic auth protection would work. But doing it manually is the same thing as robots.txt. Is there a way to automatically protect all the newly created sites (for all users or for a user) with apache basic auth (with default login/password)?
Thanks!
Are there any insights you can share? Or is it just not possible?
The only method that will work:
Create a new template for Nginx or Apache2
Create a file name with the the same template-name.sh in the same folder as the nginx or apache2 template
#!/bin/bash
user="$1"
domain="$2"
ip="$3"
home="$4"
docroot="$5"
# Command that you need to run...
Following @eris advice, here an example:
For Apache, create a default.sh script in /usr/local/hestia/data/templates/web/apache2/php-fpm/ dir with the following content:
#!/usr/bin/env bash
user="$1"
domain="$2"
home="$4"
docroot="$5"
passwd='ChangeMe'
hash="$(openssl passwd -5 "$passwd")"
fhtpasswd="${home}/${user}/conf/web/${domain}/${domain}.htpasswd"
chtpasswd="${user}:${hash}"
fhtaccess="${docroot}/.htaccess"
chtaccess="AuthUserFile $fhtpasswd
AuthName \"Auth required\"
AuthType Basic
Require valid-user"
echo "$chtaccess" >"$fhtaccess"
echo "$chtpasswd" >"$fhtpasswd"
Give exe perms to the script:
chmod +x /usr/local/hestia/data/templates/web/apache2/php-fpm/default.sh
Now, evey time you create a new web site using Apache’s default template, it will add auth to the web site using your user as default user and ChangeMe as password (remember to replace ChangeMe inside the script).
Cool, @sahsanu and @eris ! Thank you very much!
But, as I understand, that creates .htaccess file in doc root. I usually already have that kind of file in the projects I am working with. I was hoping to set basic auth through apache config, not with a file in a docroot (which would get into git changes). Can I automatically have it in VirtialHost or somewhere like that? Or maybe close the whole server altogether?
As I said, that was an example, if you have other needs you should do it in another way. In your case you should clone default templates (tpl and stpl) with another name (so it won’t get overrided in future upgrades) and do the modifications in those templates.
Example using auth as Apache’s template name:
auth.tpl
<VirtualHost %ip%:%web_port%>
    ServerName %domain_idn%
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %docroot%
    ScriptAlias /cgi-bin/ %home%/%user%/web/%domain%/cgi-bin/
    Alias /vstats/ %home%/%user%/web/%domain%/stats/
    Alias /error/ %home%/%user%/web/%domain%/document_errors/
    #SuexecUserGroup %user% %group%
    CustomLog /var/log/%web_system%/domains/%domain%.bytes bytes
    CustomLog /var/log/%web_system%/domains/%domain%.log combined
    ErrorLog /var/log/%web_system%/domains/%domain%.error.log
    IncludeOptional %home%/%user%/conf/web/%domain%/apache2.forcessl.conf*
    <Directory %home%/%user%/web/%domain%/stats>
        AllowOverride All
    </Directory>
    <Directory %docroot%>
        AllowOverride All
        Options +Includes -Indexes +ExecCGI
        AuthUserFile %home%/%user%/conf/web/%domain%/%domain%.htpasswd
        AuthName "Auth required"
        AuthType Basic
        Require valid-user
    </Directory>
    <FilesMatch \.php$>
        SetHandler "proxy:%backend_lsnr%|fcgi://localhost"
    </FilesMatch>
    SetEnvIf Authorization .+ HTTP_AUTHORIZATION=$0
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.conf_*
    IncludeOptional /etc/apache2/conf.d/*.inc
</VirtualHost>
auth.stpl
<VirtualHost %ip%:%web_ssl_port%>
    %alias_string%
    ServerAdmin %email%
    DocumentRoot %sdocroot%
        AllowOverride All
    </Directory>
    <Directory %sdocroot%>
        AllowOverride All
        SSLRequireSSL
        AuthType Basic
        Require valid-user
    </Directory>
    SSLEngine on
    SSLVerifyClient none
    SSLCertificateFile %ssl_crt%
    SSLCertificateKeyFile %ssl_key%
    %ssl_ca_str%SSLCertificateChainFile %ssl_ca%
    <FilesMatch \.php$>
    </FilesMatch>
    IncludeOptional %home%/%user%/conf/web/%domain%/%web_system%.ssl.conf_*
</VirtualHost>
auth.sh
#!/usr/bin/env bash
user="$1"
domain="$2"
home="$4"
docroot="$5"
passwd='ChangeMe'
Thanks for the wise answers! I’ve ended up putting my Hestia behind Nginx Proxy Manger. I’ve configured basic auth for all my dev sites (which are all subdomains of the same domain) there.
