Add FTP after install Hestia
I was not install FTP when install HestiaCP, now I want to add FTP service.
I already follow guide from Can I install FTP after the HestiaCP installation? - #4 by sahsanu
But I saw in list server, vsftpd keep red and wont start :frowning:
What I should do, thank you :slight_smile:
systemctl status vsftpd --no-pager -l
iptables -S | grep 12000
v-list-firewall | grep 12000
ls -l /etc/vsftpd.conf
@sahsanu after running your method in other thread, it’s working now.
But when I try login to ftp, I got this error:
Connection failed.
OOPS: cannot change directory:/srv/jail/mydomain
Instead of mydomain it should be YourUser.
Show the ouput of these commands (replace YourUser with the actual user name):
ls -la /srv/jail/YourUser
grep '^YourUser:' /etc/passwd
grep -Ev '^$|^#' /etc/ssh/sshd_config
cat /etc/vsftpd.conf
ls -la /srv/jail/myuser
ls: cannot access ‘/srv/jail/myuser’: No such file or directory
grep ‘^myuser:’ /etc/passwd
mailto:myuser:x:1003:1003:[email protected]:/home/myuser:/usr/sbin/jailbash
grep -Ev ‘^$|^#’ /etc/ssh/sshd_config
Include /etc/ssh/sshd_config.d/*.conf
LoginGraceTime 1m
PermitRootLogin yes
KbdInteractiveAuthentication no
PermitRootLogin yes
UsePAM yes
X11Forwarding yes
PrintMotd no
DebianBanner no
AcceptEnv LANG LC\_*
Subsystem sftp internal-sftp-server
UseDNS no
Match User sftp_dummy99
ChrootDirectory /srv/jail/%u
X11Forwarding no
AllowTCPForwarding no
ForceCommand internal-sftp -d /home/%u
listen=YES
anonymous_enable=NO
local_enable=YES
write_enable=YES
local_umask=022
anon_umask=022
anon_upload_enable=NO
dirmessage_enable=YES
xferlog_enable=YES
connect_from_port_20=YES
xferlog_std_format=YES
dual_log_enable=YES
chroot_local_user=YES
pam_service_name=vsftpd
ftpd_banner=Welcome! Please note that all activity is logged.
userlist_enable=NO
tcp_wrappers=YES
force_dot_files=YES
ascii_upload_enable=YES
ascii_download_enable=YES
allow_writeable_chroot=NO
local_root=/srv/jail/%u
user_sub_token=%u
seccomp_sandbox=NO
pasv_enable=YES
pasv_promiscuous=YES
pasv_min_port=12000
pasv_max_port=12100
max_per_ip=10
max_clients=100
use_localtime=NO
utf8_filesystem=YES
ssl_enable=YES
allow_anon_ssl=NO
require_ssl_reuse=NO
ssl_ciphers=ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305
ssl_sslv2=NO
ssl_sslv3=NO
ssl_tlsv1=NO
force_local_data_ssl=NO
force_local_logins_ssl=NO
rsa_cert_file=/usr/local/hestia/ssl/certificate.crt
rsa_private_key_file=/usr/local/hestia/ssl/certificate.key
Execute this:
sed -i 's/internal-sftp.*/internal-sftp/' /etc/ssh/sshd_config
systemctl restart sshd
v-add-sys-sftp-jail
If after that doesn’t work, change the shell of the user from jailbash to nologin and try again.
SFTP using port 22 is working.
FTP using port 21 not working.
Connection failed.
OOPS: cannot change directory:/srv/jail/myuser
I think it’s enough for me.
Thank you.
Edit /etc/vsftpd.conf and do these changes:
allow_writeable_chroot=YES
#local_root=/srv/jail/%u
#user_sub_token=%u
Once done, restart the service:
systemctl restart vsftpd
It’s working now.
Thank you @sahsanu
