As the title sais I want to remove the default configuration of phpmyadmin as an alias and add it as a subdomain.
I’ve tried to edit nginx and apache configuration file but without success.
How can add the new configuration?
Hi, sorry to use this thread to ask my question, but how do you get into phpmyadmin? I can’t log in from IP:8083/phpmyadmin , I’ve tried to add a host to the server but I don’t know how to do it, thanks.
https://hostname.domain.com:8083 should work fine
Use custom templates:
https://docs.hestiacp.com/admin_docs/web.html#how-do-web-templates-work
Use hestiacp/apache.conf at main · hestiacp/hestiacp · GitHub
As a basis and it should work
Thanks for the answer but i don’t really understand how to do it.
I image i have to edit the template ( don’t know how ) then from the control pannel edit the user packadge to use the new template i made ( both nginx and apache ) then create a new website and somehow point to phpmyadmin folder this way i can reach it from a subdomain. After that i have to delete or edit the pma apache.conf file so the alias no longer works.
I have a really basic knowladge about how all of this works, i’m still trying to learn
In the end I managed to do exactly what I wanted.
First I’ve disabled the current phpmyadmin configuration by renaming /etc/apache2/conf.d/phpmyadmin.inc in to phpmyadmin.inc_BACKUP.
Then I followed the docs and made the templates for apache and nginx but replacing %docroot% with phpmyadmins’ path.
In the end i created a new domain and under the advanced settings I selected the new templates that i’ve made and that worked.
Thanks for the tip @eris
