Hi!
Recently deployed a project on SULU CMS https://sulu.io/ based on Symfony https://symfony.com/. Used the Web NGINX template ‘symfony4-5’. Works well except for the operations with images in admin panel: ‘Set focus point’ and ‘Define crops’. After doing some research I found that I need to comment out the lines in the Web NGINX template ‘symfony4-5’:
location ~* ^.+\.(ogg|ogv|svg|svgz|swswf|eot|otf|woff|woff|woff2|mov|mp3|mp4|mp4|webm|flv|ttf|rss|atom|jpg|jpeg|jpeg|gif|png|webp||ico|bmp|mid|midi|wav||rtf|css|js|jar)$ {
expires 30d;
And add strings instead:
location ~* \.(?:ico|css|js|gif|webp|jpe?g|png|svg|woff|woff2|eot|ttf|mp4)$ {
# try to serve file directly, fallback to index.php
try_files $uri /index.php$is_args$args;
access_log off;
expires 1y;
add_header Pragma public;
add_header Cache-Control "public, immutable";
as recommended by SULU Nginx — Sulu 2.5 documentation .
Given that the SULU CMS https://sulu.io/ project has been active in recent years, please consider including a Web NGINX template for SULU CMS.
