curl to access the url containing "&" must add "\" in front of "&", otherwise it will not be able to read the parameters after "&", unfortunately adding "\" in front of "&" through hestiacp web interface is not valid.
v-add-cron-job luren * * * * * sudo curl https://xxxxxxx.com/cron/wztask.php?sys=1&key=673007
I can’t add \ in front of the & in the above URL, and the same problem is with the timed tasks in the web interface
