Adding a default document to an existing template
I have several domains imported to hestia that use the default/index document of “default.htm” because they originated from a Windows ASP server.
Hestia however looks for index.htm/index.html/index.php. Is there an easy way to add default.htm to the template and apply to all the domains?
Hey I found an easy way around this by using “.htaccess”. These sites were migrated from a server that did not need the below setting .htaccess.
DirectoryIndex default.htm
