So I created the nginx.conf_hsts_custom file and put in a couple of headers, checked with “nginx -t” and then restarted nginx.
But when I checked, those headers were not sent to the browser.
Then I tried this: I deleted the custom file I had created before (nginx.conf_hsts_custom) and added the headers to the file
$HOMEDIR/$user/conf/web/$domain/nginx.hsts.conf
(the conf file that Hestia creates when we activate HSTS)
I checked with “nginx -t” and then restarted nginx.
By doing it this way, everything works ok and the headers are sent to the browser.
My doubts are:
a) Why doesn’t the custom: nginx.conf_hsts_custom file works?
b) I’m not sure, but I think it is not appropriate to make customizations in “nginx.hsts.conf”, rigth? (It is possible that when HestiaCP updates, then the “nginx.hsts.conf” file it will lose those additions)
c) Maybe is better to create an Nginx template and add the headers there?
Because that is not the right file pattern The right patter is nginx.hsts.conf* so nginx.hsts.conf_custom should work.
You are right, you shouldn’t modify that file. Instead use nginx.hsts.conf_whatever or in this case, as it seems you want to add headers when ssl/tls is in use, you can use a file like nginx.ssl.conf_whatever
If you are going to use this conf in several domains, yes, I would do a template.
I forgot to comment this. Yes, that should work if your site is not redirected to https. If you only add the headers there, those headers should work on http but nginx conf for https doesn’t have those headers defined and that is the reason you can’t see them when adding that conf file.
Yeah !
That is the reason. I have the https redirection.
I suppose then the custom headers must be in a file like this:
nginx.ssl.conf_hsts_custom
right?
