I need to add a commercial “Outlook” skin1 to our Hestia Roundcube (HestiaCP v1.6.4, Roundcube v1.4.3).
According to the README from roundcube+, I should copy the contents of the skins
and plugins
folders into “the corresponding ‘skins’ and ‘plugins’ directory of my Roundcube installation.”
I found /usr/share/roundcube/
with ‘skins’ and ‘plugins’ folders, but I also found a ‘plugins’ folder in /etc/roundcube
. So, I’m scratching my head on where I should put the plugins.
I can figure it out with trial and error, but I’m hoping someone here has a deeper understanding of the Roundcube integration and can say with certainty how a 3rd party skin should be added.
The roundcube+ README also says that <roundcube>/config/config.inc.php
should be edited to add ‘xskin’ to the $config['plugins']
array and <roundcube>/config.config.inc.php
should be modified to include $config['license_key'] = 'your-license-key-here';
I found /etc/roundcube/config.inc.php
, but there is no file named ‘config.config.inc.php
’ anywhere in the HestiaCP image.
I’m guessing I should add ‘xskin’ to the /etc/roundcube/config.inc.php
file, but that probably means it will get creamed the next time HestiaCP updates Roundcube. And, I’m wondering where I should put the license key so that it gets pickup by the plugin.
Anyone been down this path already??
