HoLoD
September 21, 2023, 7:18am
1
Hi there,
I have a problem with additional ftp accounts.
Latest version Hestia 1.8.8
Open Web → Edit website → Advanced settings → Additional FTP accounts
adding account, but when I try to login via FTP, a have an error “login error” (503).
Can финищвн help me with it? Which logs I need to check?
eris
2
Check /var/log/auth.log
And see what is going wrong…
HoLoD
September 21, 2023, 7:22am
3
vsftpd:
Thu Sep 21 10:01:04 2023 [pid 490098] [mywebsite_front] FAIL LOGIN: Client “91.129.42.95” (My ip)
auth.log:
Sep 21 10:22:51 moisait vsftpd[495300]: pam_unix(vsftpd:auth): authentication failure; logname= uid=0 euid=0 tty=ftp ruser= mywebsite_front rhost=91.129.42.95 user= mywebsite_front
HoLoD
September 21, 2023, 7:37am
5
Yes, but the password is correct. copy/paste it.
sahsanu
September 21, 2023, 7:47am
6
Keep in mind that if the user is for example admin and you are adding a new ftp account like holod, the username to login via ftp is not holod, it is user_ftpaccount: In this example would be admin_holod
KRipe
September 21, 2023, 7:49am
7
I noticed that the password is not correct until you delete the account and create it again… apparently it’s a bug.
HoLoD
September 21, 2023, 9:14am
8
Yes, of course. Login is correct, mywebsite_front
HoLoD
September 21, 2023, 9:17am
9
Wow!!! Yesssss!!! If I delete account and add it again - it is works!
But if I edit account (change the password) - login impossible. This is BUG.
eris
September 21, 2023, 9:31am
10
Please create a new issue on Github
