[ * ] Backing up existing templates and configuration files…
[ ! ] Performing system health check before proceeding with installation…
[ * ] Health check complete. Starting upgrade from 1.6.8 to 1.6.8…
[ ! ] The latest version of Hestia Control Panel is already installed.
Verifying configuration…
[ * ] File Manager is up to date (7.8.2)…
[ * ] Roundcube is up to date (1.6.0)…
[ ! ] Upgrading PHPmailer to version 6.6.4…
/usr/local/hestia/bin/v-add-sys-phpmailer: line 68: /usr/local/hestia/php/bin/php: No such file or directory
[ * ] phpMyAdmin is up to date (5.2.0)…
Installation tasks complete, performing clean-up…
[ * ] Restarting services…
Error: ERROR: Restart of php7.3-fpm failed.
Error: ERROR: Restart of php7.4-fpm failed.
Error: ERROR: Restart of hestia failed.
Thanks for reply. I’ve pasted this command and what happened next(also cp panel is ‘Internal Server Error’ instead of not loading at all):
root@hcp:~# apt install --reinstall hestia-nginx
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages were automatically installed and are no longer required:
gyp javascript-common libc-ares2 libfwupdplugin1 libjs-inherits libjs-is-typedarray libjs-psl
libjs-typedarray-to-buffer libmcrypt4 libpython2-stdlib libpython2.7-minimal libpython2.7-stdlib libssl-dev
libuv1-dev python-pkg-resources python2 python2-minimal python2.7 python2.7-minimal ttf-dejavu-core
Use ‘apt autoremove’ to remove them.
hestia-nginx
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 6216 kB of archives.
After this operation, 0 B of additional disk space will be used.
Get:1 https://apt.hestiacp.com focal/main amd64 hestia-nginx amd64 1.23.1 [6216 kB]
Fetched 6216 kB in 1s (10.5 MB/s)
Selecting previously unselected package hestia-nginx.
(Reading database … 166040 files and directories currently installed.)
Preparing to unpack …/hestia-nginx_1.23.1_amd64.deb …
Unpacking hestia-nginx (1.23.1) …
Setting up hestia-nginx (1.23.1) …
Job for hestia.service failed because the control process exited with error code.
See “systemctl status hestia.service” and “journalctl -xe” for details.
invoke-rc.d: initscript hestia, action “start” failed.
Active: failed (Result: exit-code) since Fri 2022-09-23 13:13:06 UTC; 7ms ago
Process: 134994 ExecStart=/etc/init.d/hestia start (code=exited, status=2)
Tasks: 2 (limit: 1113)
Memory: 2.2M
CGroup: /system.slice/hestia.service
├─134999 nginx: master process /usr/local/hestia/nginx/sbin/hestia-nginx
└─135000 nginx: worker process
Sep 23 13:13:06 hcp.mydeveloper.co.ua systemd[1]: Starting LSB: starts the hestia control panel…
Sep 23 13:13:06 hcp.mydeveloper.co.ua hestia[134994]: * Starting hestia-nginx hestia-nginx
Sep 23 13:13:06 hcp.mydeveloper.co.ua hestia[134994]: …done.
Sep 23 13:13:06 hcp.mydeveloper.co.ua hestia[134994]: * Starting hestia-php hestia-php
Sep 23 13:13:06 hcp.mydeveloper.co.ua hestia[135001]: start-stop-daemon: unable to stat /usr/local/hestia/php/sbin/hestia-php (No such file or directory)
Sep 23 13:13:06 hcp.mydeveloper.co.ua systemd[1]: hestia.service: Control process exited, code=exited, status=2/INVALIDARGUMENT
Sep 23 13:13:06 hcp.mydeveloper.co.ua systemd[1]: hestia.service: Failed with result ‘exit-code’.
Sep 23 13:13:06 hcp.mydeveloper.co.ua systemd[1]: Failed to start LSB: starts the hestia control panel.
dpkg: error processing package hestia-nginx (–configure):
installed hestia-nginx package post-installation script subprocess returned error exit status 1
Processing triggers for systemd (245.4-4ubuntu3.18) …
hestia-nginx
