/usr/sbin/apache2ctl configtest
Syntax OK
/usr/sbin/nginx -t
systemctl status --no-pager -l php7.4-fpm
● php7.4-fpm.service - The PHP 7.4 FastCGI Process Manager
Loaded: loaded (/lib/systemd/system/php7.4-fpm.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2024-03-07 17:24:51 EST; 2h 17min ago
Docs: man:php-fpm7.4(8)
Main PID: 723 (php-fpm7.4)
Status: "Processes active: 0, idle: 0, Requests: 0, slow: 0, Traffic: 0req/sec"
Tasks: 1 (limit: 4915)
Memory: 28.7M
CGroup: /system.slice/php7.4-fpm.service
└─723 php-fpm: master process (/etc/php/7.4/fpm/php-fpm.conf)
Mar 07 17:24:50 [mydomain].com systemd[1]: Starting The PHP 7.4 FastCGI Process Manager...
Mar 07 17:24:51 [mydomain].com systemd[1]: Started The PHP 7.4 FastCGI Process Manager.
systemctl status --no-pager -l nginx
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2024-03-07 17:24:52 EST; 2h 18min ago
Docs: https://nginx.org/en/docs/
Process: 5754 ExecReload=/bin/sh -c /bin/kill -s HUP $(/bin/cat /var/run/nginx.pid) (code=exited, status=0/SUCCESS)
Main PID: 990 (nginx)
Tasks: 10 (limit: 4915)
Memory: 94.5M
CGroup: /system.slice/nginx.service
├─ 990 nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf
├─5798 nginx: worker process
├─5799 nginx: worker process
├─5800 nginx: worker process
├─5801 nginx: worker process
├─5802 nginx: worker process
├─5803 nginx: worker process
├─5804 nginx: worker process
├─5805 nginx: worker process
└─5806 nginx: cache manager process
Mar 07 17:40:14 [mydomain].com systemd[1]: /lib/systemd/system/nginx.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Mar 07 17:40:15 [mydomain].com systemd[1]: /lib/systemd/system/nginx.service:8: PIDFile= references path below legacy directory /var/run/, updating /var/run/nginx.pid → /run/nginx.pid; please update the unit file accordingly.
Mar 07 18:07:28 [mydomain].com systemd[1]: Reloading nginx - high performance web server.
Mar 07 18:07:28 [mydomain].com systemd[1]: Reloaded nginx - high performance web server.
Mar 07 18:07:29 [mydomain].com systemd[1]: Reloading nginx - high performance web server.
Mar 07 18:07:29 [mydomain].com systemd[1]: Reloaded nginx - high performance web server.
systemctl status --no-pager -l apache2
● apache2.service - The Apache HTTP Server
Active: active (running) since Thu 2024-03-07 17:41:44 EST; 2h 2min ago
Process: 15511 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Process: 5492 ExecReload=/usr/sbin/apachectl graceful (code=exited, status=0/SUCCESS)
Main PID: 15547 (apache2)
Tasks: 56 (limit: 4915)
Memory: 33.8M
CGroup: /system.slice/apache2.service
├─ 5625 /usr/sbin/apache2 -k start
├─ 5635 /usr/sbin/apache2 -k start
├─ 5636 /usr/sbin/apache2 -k start
└─15547 /usr/sbin/apache2 -k start
Mar 07 17:41:44 [mydomain].com systemd[1]: Starting The Apache HTTP Server...
Mar 07 17:41:44 [mydomain].com systemd[1]: Started The Apache HTTP Server.
Mar 07 18:07:28 [mydomain].com systemd[1]: Reloading The Apache HTTP Server.
Mar 07 18:07:28 [mydomain].com systemd[1]: Reloaded The Apache HTTP Server.
Mar 07 18:07:29 [mydomain].com systemd[1]: Reloading The Apache HTTP Server.
Mar 07 18:07:29 [mydomain].com systemd[1]: Reloaded The Apache HTTP Server.
Seeing lots of errors in the /var/log/nginx/error.log like this:
2024/03/07 17:27:56 [error] 991#991: *79 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.166.204, server: _, request: "GET /FdLf HTTP/1.1", upstream: "http://172.26.8.223:8080/FdLf", host: "54.166.112.170:80"
2024/03/07 17:28:56 [error] 991#991: *106 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.166.204, server: _, request: "GET /x3nD HTTP/1.1", upstream: "http://172.26.8.223:8080/x3nD", host: "54.166.112.170:80"
2024/03/07 18:21:13 [error] 5798#5798: *1292 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.152.66, server: _, request: "GET /VhUI HTTP/1.1", upstream: "http://172.26.8.223:8080/VhUI", host: "54.166.112.170:80"
2024/03/07 18:22:13 [error] 5798#5798: *1320 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.152.66, server: _, request: "GET /JbhI HTTP/1.1", upstream: "http://172.26.8.223:8080/JbhI", host: "54.166.112.170:80"
2024/03/07 19:16:26 [error] 5798#5798: *2771 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.165.113, server: _, request: "GET /dqgqoeCXckuwPtxov HTTP/1.1", upstream: "http://172.26.8.223:8080/dqgqoeCXckuwPtxov", host: "54.166.112.170"
2024/03/07 19:17:26 [error] 5798#5798: *2800 upstream timed out (110: Connection timed out) while connecting to upstream, client: 106.75.165.113, server: _, request: "GET /dqgqoeCXckuwPtxov HTTP/1.1", upstream: "http://172.26.8.223:8080/dqgqoeCXckuwPtxov", host: "54.166.112.170"
Last handful of errors in /var/log/apache2/error.log:
[Thu Mar 07 18:07:28.773287 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00493: SIGUSR1 received. Doing graceful restart
[Thu Mar 07 18:07:28.852777 2024] [ssl:warn] [pid 15547:tid 139756538131584] AH01909: 172.26.8.223:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 18:07:28.853213 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00489: Apache/2.4.58 (Debian) mod_fcgid/2.3.9 OpenSSL/1.1.1n configured -- resuming normal operations
[Thu Mar 07 18:07:28.853230 2024] [core:notice] [pid 15547:tid 139756538131584] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 07 18:07:29.277176 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00493: SIGUSR1 received. Doing graceful restart
[Thu Mar 07 18:07:29.355669 2024] [ssl:warn] [pid 15547:tid 139756538131584] AH01909: 172.26.8.223:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 18:07:29.356070 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00489: Apache/2.4.58 (Debian) mod_fcgid/2.3.9 OpenSSL/1.1.1n configured -- resuming normal operations
[Thu Mar 07 18:07:29.356088 2024] [core:notice] [pid 15547:tid 139756538131584] AH00094: Command line: '/usr/sbin/apache2'
[Thu Mar 07 18:07:29.696956 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00493: SIGUSR1 received. Doing graceful restart
[Thu Mar 07 18:07:29.775644 2024] [ssl:warn] [pid 15547:tid 139756538131584] AH01909: 172.26.8.223:443:0 server certificate does NOT include an ID which matches the server name
[Thu Mar 07 18:07:29.776057 2024] [mpm_event:notice] [pid 15547:tid 139756538131584] AH00489: Apache/2.4.58 (Debian) mod_fcgid/2.3.9 OpenSSL/1.1.1n configured -- resuming normal operations
[Thu Mar 07 18:07:29.776074 2024] [core:notice] [pid 15547:tid 139756538131584] AH00094: Command line: '/usr/sbin/apache2'
