Auto backups are disabled on our server currently, but I would like to manually create a backup file of a user into the current directory with v-backup-user - yet it refuses with Error: BACKUP_SYSTEM is not enabled.
Is there no flag to override this, or how about making the script aware of whether it is called automatically or manually somehow?
Okay, found it in /var/spool/cron and disabled it.
Tried to run v-add-backup-host sftp with all parameters correctly (using ssh plain password login), but it silently fails with error code 1 :c
