Good day! guys can you help me to solve this. always show up this data lose warning.
theres all the steps i follow for this nextcloud installation Best Free VPS Setup 2022 (Hestia and Oracle Cloud Free Tier) Complete Website + Email Tutorial | IdeaSpot
eris
2
Delete all files in the /home/user/web/domain/public_html folder
after deleting all the files and reinstall nextcloud
eris
4
Make sure to also delete the hidden files
after delete all files folder in public_html and hidden files and try to reinstall nc
eris
7
Check your web logs /home/user/web/domain/logs/
[Thu Jun 02 06:18:30.997684 2022] [autoindex:error] [pid 85544:tid 140542386099968] [client 162.142.125.210:0] AH01276: Cannot serve directory /home/swordz/web/nc.swordz.xyz/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
[Thu Jun 02 06:18:31.446805 2022] [autoindex:error] [pid 85543:tid 140542518122240] [client 162.142.125.210:0] AH01276: Cannot serve directory /home/swordz/web/nc.swordz.xyz/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
[Thu Jun 02 06:18:50.441825 2022] [autoindex:error] [pid 85544:tid 140542369314560] [client 195.211.77.140:0] AH01276: Cannot serve directory /home/swordz/web/nc.swordz.xyz/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
[Thu Jun 02 06:19:51.372903 2022] [autoindex:error] [pid 85544:tid 140542360921856] [client 3.86.183.77:0] AH01276: Cannot serve directory /home/swordz/web/nc.swordz.xyz/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
[Thu Jun 02 06:20:18.985619 2022] [autoindex:error] [pid 85544:tid 140542344136448] [client 45.132.227.113:0] AH01276: Cannot serve directory /home/swordz/web/nc.swordz.xyz/public_html/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
i create new domain and install nc and warning show up again
swordz
10
thankyou so much for helping me.
eris
11
Does the .htaccess file exists in the root of /public_html?
swordz
13
i try to install nc manually but same result
swordz
15
problem solve! i create instance with 24GB ram XD i think hestiaCP needs more ram to install nc without error
chris
16
swordz
17
i have 1gb ram before and now work with 24 gb ram
eris
18
1 GB is a litte bit low… 24GB is the other extreme…
