Anormalidad / Abnormality
Revisando los archivos log desde filegator y terminal no hay similitudes, creo que esto es un grave error.
¿Qué les parece?
Reviewing the log files from filegator and terminal there are no similarities, I think this is a serious error.
What do you think?
Log files are limited to root permissions and that is Is why it is causing the error
But you’re not supposed to show that information to a normal user unless you can modify it.
Users can access the logs via:
