Apach2 restart failed
Hi
i am try to issu lets encrypt SSL after 2/3 days facing error apache2 not restar error
can anyone help me
note not much knowledge cli
root@digitechpk:~# systemctl status apache2
× apache2.service - The Apache HTTP Server
     Active: failed (Result: exit-code) since Thu 2023-12-21 16:39:47 UTC; 4min 20s ago
    Process: 7880 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
        CPU: 63ms
Dec 21 16:39:47 digitechpk.us.to systemd[1]: Starting The Apache HTTP Server...
Dec 21 16:39:47 digitechpk.us.to apachectl[7882]: AH00526: Syntax error on line 32 of /etc/apac>
Dec 21 16:39:47 digitechpk.us.to apachectl[7882]: SSLCertificateChainFile: file '/home/admin/co>
Dec 21 16:39:47 digitechpk.us.to systemd[1]: apache2.service: Control process exited, code=exit>
Dec 21 16:39:47 digitechpk.us.to systemd[1]: apache2.service: Failed with result 'exit-code'.
Dec 21 16:39:47 digitechpk.us.to systemd[1]: Failed to start The Apache HTTP Server.
Check Lin 32 of this file…
how to check this file
sorry for having less knowledge of cli
sudo nano /etc/apac is blank
The output you posted is not showing the full line.
Execute this command to view the entire lines:
systemctl --no-pager -l status apache2
root@digitechpk:~# systemctl --no-pager -l status apache2
     Active: failed (Result: exit-code) since Thu 2023-12-21 18:13:12 UTC; 4min 21s ago
    Process: 42015 ExecStart=/usr/sbin/apachectl start (code=exited, status=1/FAILURE)
        CPU: 19ms
Dec 21 18:13:12 digitechpk.us.to systemd[1]: Starting The Apache HTTP Server...
Dec 21 18:13:12 digitechpk.us.to apachectl[42017]: AH00526: Syntax error on line 32 of /etc/apache2/conf.d/domains/digitechpk.us.to.ssl.conf:
Dec 21 18:13:12 digitechpk.us.to apachectl[42017]: SSLCertificateChainFile: file '/home/admin/conf/web/digitechpk.us.to/ssl/digitechpk.us.to.ca' does not exist or is empty
Dec 21 18:13:12 digitechpk.us.to systemd[1]: apache2.service: Control process exited, code=exited, status=1/FAILURE
Dec 21 18:13:12 digitechpk.us.to systemd[1]: apache2.service: Failed with result 'exit-code'.
Dec 21 18:13:12 digitechpk.us.to systemd[1]: Failed to start The Apache HTTP Server.
To view line 32 edit file with vi, nano… or execute this command:
sed -n '32p' /etc/apache2/conf.d/domains/digitechpk.us.to.ssl.conf
is working remove ssl
thanks sahsanu
