Dear Hestia Team, I have a question, where can i find the regular Apache File for Webserver.
Because i must adjust my Apache file for Nuxt etc…
Can someone help me?
Best regards
Markus
Best regards
Markus
@falzo Könntest du mir evtl. helfen mit den Apache Einstellungen?
Ich bin neu bei Hestia und bräuchte echt Hilfe.
Hey Markus,
best place to start is reading the general documentation. You want to focus on the creation of templates for apache/nginx: Web Templates and FastCGI/Proxy Cache | Hestia Control Panel
in a nutshell: working directly in the config files will not stick and might get overwritten by updates or other tasks later on. you want to create a configuration template that holds all the settings needed for your app and then select this within the webdomain settings to be used.
and I am sorry, but I can’t help you create that template for you. maybe someone else in the community is willing to help out, if you can’t get it working.
