Hello.
I think the best way for me to answer this question is to manually build a server, gain some knowledge and see how all the components need to be setup to communicate with each other.
However at the moment I’m hoping someone can give me a quick answer.
I’m using Hestia with the webserver setup as Apache + NGINX + PHP-FPM
Some of the PHP sites show a gateway timeout.
Previously (and a long time ago), I’ve only had to worry about Apache and just made changes using .htaccess.
Is anyone able to tell me how Apache, NGINX and PHP-FPM all relate to each other?
I changed the max_execution_time in PHP but it didn’t make any difference. Then using Google I started seeing a lot of “fixes” that might cause a gateway error.
Is anyone able to point me in the right direction to resolve this problem on a server setup with Hestia CP?
Thanks!
