Hi folks,
standard installation with bash hst-install.sh works fine and hassle-free.
However, I don’t want Nginx, only Apache with PHP. But when I try bash hst-install.sh -a yes -n no -w yes the installation fails with following errors:
The following server components will be installed on your system:
- Apache Web Server
- PHP-FPM Application Server
- Bind DNS Server
- Exim Mail Server + ClamAV + SpamAssassin
- Dovecot POP3/IMAP Server
- MariaDB Database Server
- Vsftpd FTP Server
- Firewall (Iptables) + Fail2Ban Access Monitor
Would you like to continue with the installation? [Y/N]: y
Please enter admin email address: [email protected]
Please enter FQDN hostname [test.my-domain.de]:
Installation backup directory: /root/hst_install_backups/220320202145
Installation log file: /root/hst_install_backups/hst_install-220320202145.log
(*) NGINX
(*) PHP
(*) MariaDB
(*) Hestia Control Panel
Extracting templates from packages: 100%lease wait...| \
Now installing Hestia Control Panel and all required dependencies.
NOTE: This process may take 10 to 15 minutes to complete, please wait... \
(*) Configuring system settings...
(*) Configuring Hestia Control Panel...
cp: cannot stat '/usr/local/hestia/install/deb/sudo/admin': No such file or directory
chmod: cannot access '/etc/sudoers.d/admin': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/hestia': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/packages': No such file or directory
sed: can't read /usr/local/hestia/data/packages/*.pkg: No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/unassigned/index.html': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/templates/web/skel/document_errors/*': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/firewall': No such file or directory
(*) Generating default self-signed SSL certificate...
hst-install-debian.sh: line 1111: /usr/local/hestia/bin/v-generate-ssl-cert: No such file or directory
(*) Adding SSL certificate to Hestia Control Panel...
sed: -e expression #1, char 3: unexpected `,'
sed: -e expression #1, char 1: unknown command: `,'
cp: cannot stat '/usr/local/hestia/install/deb/ssl/dhparam.pem': No such file or directory
(*) Configuring Apache Web Server...
cp: cannot stat '/usr/local/hestia/install/deb/apache2/apache2.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/apache2/status.conf': No such file or directory
cp: cannot stat '/usr/local/hestia/install/deb/logrotate/apache2': No such file or directory
hst-install-debian.sh: line 1184: /etc/apache2/sites-available/default: No such file or directory
hst-install-debian.sh: line 1185: /etc/apache2/sites-available/default-ssl: No such file or directory
hst-install-debian.sh: line 1187: /etc/apache2/suexec/www-data: No such file or directory
touch: cannot touch '/var/log/apache2/access.log': No such file or directory
touch: cannot touch '/var/log/apache2/error.log': No such file or directory
chmod: cannot access '/var/log/apache2/access.log': No such file or directory
chmod: cannot access '/var/log/apache2/error.log': No such file or directory
Failed to start apache2.service: Unit apache2.service not found.
Error: apache2 start failed
Is it a bug or is an Apache system without Nginx simply not supported?
Server: Hetzner Cloud 2 GB RAM
Operating system: Debian 10 Buster
Panel Version: 1.1.0 stable release on March 11th, 2020
Thanx and good health
Nifoco
