I need that loja.mysite.com coming through the loja.anotherdomain.com
From what I saw I will have to configure nginx to accept any domain through a wildcard “*”
My question would be, when doing this and if the system is updated, or hestip is updated, in short, is there a way to permanently keep the settings made in Nginx or Apache, without undergoing any kind of unscheduled change?
“Avoid modifying default templates as they are overwritten by updates.”
So even if I modify the nginx template, located in “/usr/local/hestia/data/templates/web/nginx/” when hestiacp is updated will the template be replaced by a new template?
Is there any way this change can be applied forever? I suppose disabling automatic hestiacp updates would do the trick, correct? Today I have only 1 user for 1 system and it will be like this “forever” in this vps.
