Appetite for small, init-agnostic robustness in service handling? (context: running HestiaCP in a container)
Hi HestiaCP team :waving_hand:
First - thanks for HestiaCP. Upfront: I know Docker isn’t officially supported, and I’m not asking you to support it. I maintain a community image + an Umbrel app on my own (ptrinh/hestiacp-docker) and it works well as a control panel. I only want to gauge whether you’d be open to a few small, environment-agnostic robustness changes that surfaced - ones I believe are harmless (or mildly positive) on a normal systemd install too. If it’s “out of scope,” totally fair and I’ll keep everything downstream.
What I observed: The panel runs fine non-privileged. The fragile spot without systemd is live web changes (e.g. v-add-web-domain): HestiaCP runs v-restart-service → systemctl reload-or-restart <web/php> and verifies the result. When PID 1 isn’t systemd, a restart can report failure and leave nginx/php-fpm down until the next clean start. I work around it by regenerating configs from persisted data + one clean restart at container start (v-rebuild-user), which is reliable - but live ops stay best-effort.
Questions:
  1. Open in principle to PRs making service control a thin, pluggable abstraction (one v-restart-service indirection targeting systemd or a generic service/supervisor backend) - systemd staying the default and only supported path?
  2. Or, smaller: accept making a restart’s status check more resilient (warn-and-continue when the init system can’t report status), without changing behaviour on supported OSes?
  3. Or keep this entirely in community images (no core changes)?
Happy to do the work and keep it minimal/opt-in - just want direction before opening anything. Thanks!
